Root password
Root password
Postby Johnnie » Sun Jul 01, 2012 6:00 pm
I installed the Ubuntu 12.04 from LXF159 and ran into a problem with the root password when I tried to use the command line and SU. It kept telling me my password was invalid. The Ubuntu documentation on 12.04 says the first user password defined on installation will be the root password. I have no problem logging on to the system with this password (meaning there are no typos). Any help on this or is my next step to re-install?
Johnnie
Postby towy71 » Sun Jul 01, 2012 6:26 pm
you need to use sudo rather than su http://en.wikipedia.org/wiki/Sudo
Thank you
Postby Johnnie » Mon Jul 02, 2012 3:47 am
Thanks for the quick info. Guess I'm too old. :lol:
Johnnie
Re: Thank you
Postby lok1950 » Mon Jul 02, 2012 4:50 am
Johnnie wrote:Thanks for the quick info. Guess I'm too old. :lol:
We all have our senior moments Johnnie :roll: Ubuntu does not put a real root account on their distro so if you are used to using su or su - for root access it's not there :roll:
Enjoy the Choice :)
lok1950
Postby Ram » Mon Jul 02, 2012 8:03 am
But is if you sudo su
Postby ajgreeny » Mon Jul 02, 2012 12:32 pm
Ram wrote:But is if you sudo su
Still uses the user password, though, not a root password.
ajgreeny
Postby Ram » Mon Jul 02, 2012 12:40 pm
Only the once then you have full root access as far as I can tell until you close the terminal it was issued from.
Postby ajgreeny » Mon Jul 02, 2012 6:54 pm
We're probably splitting hairs here, but it is still not really using the root account, as far as I'm aware, but just raising the user to temporary root permissions.
I agree, however, it can be useful if you're doing something that requires continual re-entry of the sudo password, as that terminal retains root permissions until closed; one reason why using sudo su is rather frowned on by ubuntuforums, if not quite banned from being talked about.
ajgreeny
Root Password
Postby Johnnie » Mon Jul 02, 2012 9:59 pm
This discussion brings up the question of the root password. Once I am in root and change the password using passwd XXXX does this also change the user password. And if I were back in user mode and changed the password of the initial user would the root password change?
Johnnie
Postby nelz » Mon Jul 02, 2012 10:58 pm
No and no. Each user has their own password, and only root is able to change the password of anyone else.
Postby GregS » Tue Jul 03, 2012 12:46 am
AFAIK from my irregular interactions with the big 'U',
sudo bash
provides the same utility (ie remains as root for the duration of the session...)
GregS
Postby ajgreeny » Tue Jul 03, 2012 10:12 pm
Yes, so does
sudo -i
but it still only uses the user password, not a root password, and raises the user to root permissions.
Either way, as I said before, I think we are just splitting hairs with this discussion.
ajgreeny
Postby Ram » Tue Jul 03, 2012 10:32 pm
ajgreeny wrote:Yes, so does
sudo -i
Hair splitting maybe but I think the OP miss used su instead of using sudo.
