"Compacting" folder.
catgate
PostPosted: Fri Jun 29, 2012 10:23 pm    Post subject: "Compacting" folder. Reply with quote
I have recently started getting a pop up in Thunderbird asking me if I would like folders compacting. I thought it a bit odd and wondered if it was a new "feature". So I looked up "compacting" on the Mozilla site :-
"Compact Inbox or Other Folder
Thunderbird folders (including the Inbox, Drafts, etc) are stored in files on the local hard drive. As messages are added to folders, the files grow larger. However, when you delete a message or move it from one folder to another, the file containing the folder does not automatically get smaller. To reduce the file size, folders can be compacted."
Does this really mean that despite the fact I have "deleted" messages they are still there occupying space, and lurking "incognito"?
Oh, sod it.
MartyBartfast
PostPosted: Fri Jun 29, 2012 10:36 pm    Post subject: Reply with quote
Yes and if you find the file containing that folders messages you can view that file and see the deleted mail contents.
Once you compact the folder it removes deleted messages from the files.
PostPosted: Sat Jun 30, 2012 12:15 am    Post subject: Reply with quote
Indeed, my father never compacts email folders, so when I have upgraded his computer and imported his old emails, he gets back all the ones he thought he'd deleted as well. Rolling Eyes
Debian Acolyte
PostPosted: Sat Jun 30, 2012 1:14 am    Post subject: Reply with quote
I must wonder at the logic behind such a setup. I cannot see an advantage in retaining "deleted" files. After all, delete means "delete", not hide. Perhaps it is the developers' misguided way of preventing accidental deletion?
Debian Stable
Openbox
PostPosted: Sat Jun 30, 2012 7:13 am    Post subject: Reply with quote
If it's an mbox, then strictly speaking it isn't retaining a file, mboxes can be opened as one long text file in an editor.
OTOH, we all know, do we not, that when we delete files from a file system, the file itself is not deleted, only its reference in the file allocation table (or similar).
MartyBartfast
PostPosted: Sat Jun 30, 2012 8:18 am    Post subject: Reply with quote
It's even more bizzare than that, when you 'delete' a mail in Thunderbird you then end up with TWO copies of the text! As it moves the mail to the Trash folder, and marks the mail as being deleted from the original folder but as discussed above the original text is still in the folder mbox.
I've a feeling that when you empty the trash folder it automatically compacts that folder but can't be 100%.
This has been a bit of a pain in the past when I've been sent a dodgy Email that I delete immediately, but then my regular virus scan detects the infection on the associated folder and will continue to do so until it gets compacted.
Debian Acolyte
PostPosted: Sat Jun 30, 2012 9:00 am    Post subject: Reply with quote
I do not use applications like Thunderbird, so I must ask; Can the mail be deleted with Shift+Del like with a file manager, or must they be deleted with the two-step process of delete followed by compact?
Debian Stable
Openbox
MartyBartfast
PostPosted: Sat Jun 30, 2012 10:18 am    Post subject: Reply with quote
A quick experiment shows that shift+del will not send the message to the trash folder, but it still leaves the message text in the original folder until such time as it is compacted.
There's also an option under Preferences /Network & Disk space for
"Compact folders when it will save over ?? MB", so by choosing a suitably low value for ?? (min=1) it should compact the folders automatically on a more frequent basis.
Debian Acolyte
PostPosted: Sat Jun 30, 2012 10:53 am    Post subject: Reply with quote
Thanks for the information. Myself, I believe "compact folder" is a poor term to use. Perhaps something like "Empty deleted messages" would be better? Oh well. Since I do not use it, it does not affect me. Very Happy
By the way. Your signature frightens me a little. Laughing
Debian Stable
Openbox
PostPosted: Sat Jun 30, 2012 12:44 pm    Post subject: Reply with quote
By the way, it's not only Thunderbird that behaves this way, I was actually migrating my father's e-mail from KMail to Thunderbird, but I was aware from my own experience of Thunderbird that things are no different there.
catgate
PostPosted: Sat Jun 30, 2012 12:56 pm    Post subject: Reply with quote
When I used to use M$ stuff I always thought, and never saw any reason to doubt the idea, that, when its reference was removed from the FAT, the space occupied by the file, whose "pointer" had been removed, was free to be reallocated for over writing.
The suggestion of compacting in Thunderbird seems to indicate that that space will now simply be zipped.
Oh, sod it.
PostPosted: Sat Jun 30, 2012 7:54 pm    Post subject: Reply with quote
It's about efficiency. If the whole file had to be rearranged every time you tried to remove a few kB from the middle of it, you'd soon be complaining about how slow your mailer had become.
The real answer is to not use mbox files at all. Maildir stores each mail as a separate file, so deletion is quick and easy, and the space it used becomes available immediately. Minimising the loss caused by one file being corrupted is also a very good reason to avoid mbox.
PostPosted: Sat Jun 30, 2012 8:28 pm    Post subject: Reply with quote
I'm inclined to wonder about that nelz, one of the problems with moving from KMail to Thunderbird is that the latter can't import KMail's folders, which default to maildir. So, one needs to export the emails to mbox format before importing them into Thunderbird. Umpteen such stories are to be found by searching for "migrate kmail to thunderbird". And that was how I did it.
If emails are deleted properly using maildir then I wouldn't have expected to see old emails turning up when importing the mbox into Thunderbird.
PostPosted: Sat Jun 30, 2012 10:27 pm    Post subject: Reply with quote
There is the facility with maildir to mark mails for deletion but delete them later. It is useful with IMAP sessions as all the mails can be marked then deleted at the end of the session, but there's no point in using it with a local mail store. Not that having a point has much bearing on decisions regarding KDE's PIM suite Sad
