2tux-zx7r
Posted: Tue Jun 26, 2012 5:54 pm Post subject: Raspberry Pi tutorials - problems |
OK so second time playing with the new Pi. First one was to get it all installed and check everything worked. Passed that.
Tonight it was work through the tutorials in LXF159 and 160
1st issue: I don't know the root password. Haven't found it in the articles but if I want to start GParted from the menu it asks for it. I know I could sudo from a terminal but I like having a root password. Is there one set up or shall I add the user root?
2nd issue: I don't have /boot/config.txt for fixing the overscan issue. As I installed from LXF159 have you used some other distro for the tutorial?
Cheers
John |
2tux-zx7r
Posted: Tue Jun 26, 2012 6:15 pm Post subject: Found answer to the root password problem |
Been onto the Pi website and found the answer to the root password problem
So just the missing config.txt to sort out (for the moment anyway!)
John |
2tux-zx7r
Posted: Tue Jun 26, 2012 6:21 pm Post subject: Missing config.txt = resolved |
This answer found on the Pi website as well. Sorry for taking up bandwidth here guys!
Need to create (touch) it  |
Dutch_Master LXF regular
Posted: Tue Jun 26, 2012 6:55 pm Post subject: |
That's OK, it's been quiet lately. Our resident forum troll seems to have vacated the premises  |
towy71 Moderator
Posted: Tue Jun 26, 2012 7:14 pm Post subject: |
| Dutch_Master wrote: | Our resident forum troll seems to have vacated the premises  | Oh dear you know what'll happen now
It was DM wot done it 'onest  _________________ still looking for that door into summer |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1547 Location: Guisborough
Posted: Tue Jun 26, 2012 7:26 pm Post subject: |
There is no plaice here for the fish... _________________
dhester
Posted: Tue Jun 26, 2012 8:05 pm Post subject: |
| 2tux-zx7r for others who might have the same problem could you post the answers or links to the answers. |
2tux-zx7r
Posted: Tue Jun 26, 2012 8:24 pm Post subject: Completing the circle |
| dhester wrote: | | 2tux-zx7r for others who might have the same problem could you post the answers or links to the answers. |
yeah sorry mate. Mea culpa, Bloody bad manners of me
Issue#1: Root password
By default there is no root password
Options are:
A) set global sudo - in a terminal type "gconftool-2 -\-type bool -\-set /apps/gksu/sudo-mode true"
B) instead of logging in as a user at the first terminal screen, log in as root. At the terminal prompt type "sudo su" and then "startx" X11 runs as root and won't ask for root passwords
C) Set a root password. In a terminal type "sudo passwd root"
Issue#2: Missing config.txt
By default this file is not there.
Create one by typing in a terminal "touch /boot/config.txt"
This can be populated by reading the advice at http://elinux.org/RPi_config.txt
John |
nelz Moderator
Posted: Tue Jun 26, 2012 8:54 pm Post subject: |
| Ram wrote: | | There is no plaice here for the fish... |
Except in a fish pi.
It's unlike the fat one to ignore a thread with food references, no matter how vague. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
dhester
Posted: Tue Jun 26, 2012 9:08 pm Post subject: |
Thanks 2tux-zx7r.
I ordered my Raspberrypi last week now got to wait 10 weeks. |
Ram LXF regular
Posted: Tue Jun 26, 2012 10:00 pm Post subject: Re: Completing the circle |
| 2tux-zx7r wrote: | | dhester wrote: | | 2tux-zx7r for others who might have the same problem could you post the answers or links to the answers. |
Options are:
John |
I'll disagree with B, you should be able to login as a user then sudo su there is no need to sudo su once you are root.
sudo su will only ask for the password once. _________________
2tux-zx7r
Posted: Wed Jun 27, 2012 6:55 am Post subject: |
I think I may have written B poorly
I think the advice means instead of logging in when the system boots as user "pi" log in with "sudo su" then do "startx"
Personally I just set a root password and have had no problems since |
AgeGap1
Posted: Fri Nov 30, 2012 9:39 pm Post subject: |
| Hi, I have just got a Raspberry Pi and have encountered a problem. It is running squeezy and LXDE. When I try to look at the bottom of a Window I am unable to scroll to the bottom. I have tried making the window smaller and pushing it to the top of the screen but I still can't see the bottom of the Window. I have tried google for the solution. Any help would be appreciated. I am using composite cables not hdmi. |
Ram LXF regular
Posted: Fri Nov 30, 2012 10:03 pm Post subject: |
Try changing your TV resolution - maybe auto so the screen might resize. _________________
Posted: Fri Nov 30, 2012 11:50 pm Post subject: |
| You may have overscan enabled for a regular TV, try to disable it. |
