Any subscribers got the Firefox
How do you rate LXF 66?
Poll ended at Fri May 06, 2005 11:01 pm
Poor
0
No votes
Okay
3
15%
Excellent
17
85%
Total votes : 20
Postby Gordon » Fri Apr 15, 2005 5:41 pm
Greatmag. I've still got every copy from the preview Linux Answers and have subscribed from about issue 3. The mag just keeps getting better. I can only say, 'Start selling binders for the mag'. It's a great source of reference material. Maybe you could create an index for each binder so I can find those articles from years ago with ease.
Gordon
Postby skecs » Fri Apr 22, 2005 10:16 am
Just a quick thought about the code issues - any chance of them being an ASCII file or files on the DVD under the Magazine folder (Coding).
I was just having some gawk errors with the shell script in "A Space Odyssey" in the Tutorials section. It came back to having the spaces wrong which is easy to do in non-monospaced text (which takes up lots of room on paper).
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
skecs
Postby graham » Mon Apr 25, 2005 12:05 pm
Here's my final space odyssey script:
#!/bin/bash
TMP="/tmp"
SRC="http://antwrp.gsfc.nasa.gov/apod/"
PGE="astropix.html"
cd ${TMP}
wget --quiet $SRC$PGE
image=`gawk -F \" '/href="image/ { print $2; exit; }' $PGE`
wget --quiet $SRC$image
filename="${image##*/}"
cp -rf $TMP/$filename $HOME/.kde/share/background
dcop kdesktop KBackgroundIface setBackgroundEnabled false
dcop kdesktop KBackgroundIface setWallpaper $HOME/.kde/share/background 6
dcop kdesktop KBackgroundIface setBackgroundEnabled true
rm -rf $TMP/$filename
rm -rf $TMP/$PGE
This script needs to go into your path (such as $HOME/bin). The dcop stuff won't work from cron, because it doesn't know about the KDE session. You can get around this in KDE by using kalarm for scheduling instead.
graham
Postby donoreo » Tue Apr 26, 2005 2:59 pm
It was a very good issue (and the first of my subscription, no more running around to find it) including the usual assortment of typos and spelling errors :)
Don in Canada
donoreo
Postby ryptyde » Wed Apr 27, 2005 2:13 am
I enjoyed the Firefox write-up and also found the "Firefox Tip" on the side panels useful
as I read,browse and tweak.GCC 4.0 article was not so exciting (due to my ignorance)but
I read it through to the end and will no doubt be utilising it in the near future.
The tutorials are a joy and have been following the GIMP closely.
Keep up the good work.
Phil
ryptyde
Postby skecs » Tue May 03, 2005 8:02 am
Hi graham,
Thanks for the nasa script in monospace fonts - works a treat!!
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
skecs
