De-internet-archive-scripting webpages
Postby Dutch_Master » Sun Mar 25, 2012 9:18 pm
Some time ago I downloaded a website from the internet archive pages as it turned out the owner discontinued it. They insert some ***** scripting I distaste greatly and it keeps on linking to the archive. I could remove all instances by hand in the html code, but with 100+ pages, I'd think there's a better (quicker!) solution. I assume sed or awk are required, but knowing nought about either, what's the best oneliner (or script, that's fine) that get me running? (s'cuse the pun ;))
Postby nelz » Mon Mar 26, 2012 12:55 am
If the code is in the same place in each file, you can remove a range of line with
for i in *.html; do
  sed -i x-yd $i
done
Where x and y are the first and last lines of the script. Otherwise we'd need to see an example to see how to identify the lines to be deleted.
Postby Dutch_Master » Mon Mar 26, 2012 1:32 am
The problem is that although the archive script puts a lot of files in the same place, it also hard-links all links in a page, using absolute links (with the http header). However, when storing the files I also introduced some issues, only to become apparent when I opened the html code.... Right now, I think your script will remove the bulk of the added code and I'd have to manually edit the hard-links back to relative links. Thanks again Nelz!
[edit: cried victory too soon, after replacing the x and y with numerical values I got the error
sed: -e expression #1, char 3: unknown command: `-'
I've got as far as
for i in *.html; do sed i\ {14-216}d $i; done
This clears the files completely. Luckily I got a backup.... ;)]
[edit2: here's a simple sample]
Postby nelz » Mon Mar 26, 2012 9:34 am
My bad, I was working from failing memory, it is x,yd not x-yd, which means something completely different.
You can also give an extension to -i and sed will create backups of the original files with that extension. This will remove the toolbar stuff and save a backup
sed -i.bak /BEGIN\ WAYBACK\ TOOLBAR/,/END\ WAYBACK\ TOOLBAR/d Start\ page.html
You can change the links to relative with something like
sed 's/http:\/\/web.archive.org\/web\/20041103050546\/http:\/\/web.utanet.at\/smiderkr\/asr\//g'
on all files in the same directory, but it gets messy if the pages are stored in multiple subdirectories.
Postby Dutch_Master » Mon Mar 26, 2012 1:06 pm
Thanks Nelz, give it a try later. :)
Postby Dutch_Master » Thu Jun 21, 2012 2:07 pm
And again I find some familiar question in LFX159 this time :D Thx guys!
(haven't pursued it yet, got some RSI complaints by my wrist back then... :()
