bloody mtp!!!
bloody mtp!!!
Postby heiowge » Sat Jun 09, 2012 7:32 pm
Anyone know how I can get my mp3s on an old sony mp3 player I've resurrected? Just point me at a tutorial if you want. My problem is it uses MTP - something I've never used.
My google skills have failed me. All I can find is that some programs do support it or guides to using it with an ipod.
ta.
Postby lok1950 » Sat Jun 09, 2012 8:51 pm
If I remember correctly there is a mtp package that is used by both Rhythm Box and Amarok.
Enjoy the Choice :)
lok1950
Postby heiowge » Sat Jun 09, 2012 10:00 pm
I couldn't get the amarok one working. :(
Postby ajgreeny » Sun Jun 10, 2012 11:48 am
Have you tried changing the Sony mp3 player setup to use usb mass storage mode? I have a small simple mp3 player that defaulted to mtp mode, which was definitely not my choice, but a quick search soon found how to change it to usb mass storage.
ajgreeny
Postby Fat_Tuesday » Sun Jun 10, 2012 12:07 pm
Fat_Tuesday
Postby TheLiquidator » Mon Jul 16, 2012 12:41 pm
Don't know if you fixed it yet but in case not one very important file I think you need is mtp-tools. I needed that to copy files from Amarok to my Samsung Galaxy from kubuntu 12.04.
It's in the repo.
HTH
Ian
Edit - I note it is the 2nd article entry referred to by Fat_Tuesday. I found that single file to be the "silver bullet".
TheLiquidator
