Python module version types.
What module version type do you prefer?
String (eg. 1.2.3)
2
33%
Tuple (eg. (1, 2, 3))
4
67%
Total votes : 6
Postby Lejon » Sat Oct 22, 2005 9:16 pm
The 2 most common types for module versions seams to be
string (eg. 1.2.3) and tuple (eg. (1, 2, 3)).
Witch of thes two do you prefer?
My thoughts.
The String one can ofcourse be printed easaly for a report.
While the tuple is easyer for advanced compair.
And I find it easyer/faster to convert from tuple to string, than from string to tuple.
Do'h, cant Edit the Pool question.
Ofcourse it is ment to be "do..." not "fo..."
I am the one you thought I was! Just not the way, you expected...
Lejon
RE: Python module version types.
Postby M-Saunders » Mon Oct 24, 2005 8:17 am
Corrected :-)
M
M-Saunders
Re: RE: Python module version types.
Postby Lejon » Mon Oct 24, 2005 8:21 am
M-Saunders wrote:Corrected :-)
M
Thanx :D
Now if people only could start to vote!
Am I the only python dev here? I know I am not alone!
Lejon
RE: Re: RE: Python module version types.
Postby overflow » Mon Oct 24, 2005 12:29 pm
Our version numbers are inserted by CVS so it has to be strings.
overflow
overflow
Re: RE: Re: RE: Python module version types.
Postby Lejon » Mon Oct 24, 2005 12:32 pm
overflow wrote:Our version numbers are inserted by CVS so it has to be strings.
Dose not "has to be".
As you can easy create a function that can return it as a tuple.
However I see your point.
Lejon
Users browsing this forum: Exabot [Bot] and 1 guest
