dual monitors
dual monitors
Postby pedros » Mon Jun 04, 2012 10:14 am
hello all,
new job, new pc... obviously with a non-standard size case so the video card wont fit.
on board amd radeon 6310 video card has two outputs, vga and hdmi. don't want to open brand new second monitor to test if it will need to be returned but is it likely i can run both monitors from the existing video card?
pedros
Postby heiowge » Mon Jun 04, 2012 10:22 am
Can you drill a hole in the case to make it fit? :lol:
Postby wyliecoyoteuk » Mon Jun 04, 2012 11:00 am
What motherboard?
Some will, some won't
e.g.my ASrock a75m will.
Postby pedros » Mon Jun 04, 2012 1:11 pm
its this piece here,
http://www.pcworld.co.uk/gbuk/acer-aspi ... 4-pdt.html
knew i should have just gone to the shop myself rather than letting sales people buy me stuff.
pedros
Postby pedros » Mon Jun 04, 2012 1:27 pm
sudo lshw provides the following details
xubuntu
    description: Desktop Computer
    product: Aspire X1430 (To be filled by O.E.M.)
    vendor: Acer
    serial: DTSJ5EK004211021579201
    width: 64 bits
    capabilities: smbios-2.7 dmi-2.7 vsyscall32
    configuration: administrator_password=disabled boot=normal chassis=desktop family=Acer Desktop power-on_password=disabled sku=To be filled by O.E.M. uuid=C89CDCA7-53DC-2012-0312-130009000000
  *-core
       description: Motherboard
       vendor: Acer
       physical id: 0
     *-firmware
          description: BIOS
          vendor: AMI
          physical id: 0
          version: P01-C1
          date: 11/16/2011
          capacity: 1984KiB
          capabilities: pci apm upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification
     *-cpu
          description: CPU
          product: AMD E-300 APU with Radeon(tm) HD Graphics
          vendor: Hynix Semiconductor (Hyundai Electronics)
          physical id: 4
          bus info: cpu@0
          version: AMD E-300 APU with Radeon(tm) HD Graphics
          serial: To Be Filled By O.E.M.
          slot: CPU 1
          capacity: 1300MHz
          width: 64 bits
          clock: 100MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp constant_tsc rep_good nopl nonstop_tsc extd_apicid aperfmperf pni monitor ssse3 cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch ibs skinit wdt arat npt lbrv svm_lock nrip_save pausefilter cpufreq
          configuration: cores=2 enabledcores=2 threads=2
        *-cache:0
             description: L1 cache
             physical id: 5
             slot: L1-Cache
             capacity: 128KiB
             capabilities: internal write-back unified
        *-cache:1
             description: L2 cache
             physical id: 6
             slot: L2-Cache
             capacity: 1MiB
             capabilities: internal varies data
     *-memory
          description: System Memory
          physical id: 24
          slot: System board or motherboard
        *-bank:0
             description: DIMM Synchronous [empty]
             vendor: Manufacturer1
             physical id: 0
             serial: SerNum1
             slot: DIMM1
        *-bank:1
             description: DIMM DDR3 Synchronous 1333 MHz (0.8 ns)
             product: ACR512X64D3U13C9G
             vendor: Kingston
             physical id: 1
             serial: 3A3C52CB
             slot: DIMM2
             width: 64 bits
             clock: 1333MHz (0.8ns)
     *-pci:0
          description: Host bridge
          product: Family 14h Processor Root Complex
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 00
          width: 32 bits
          clock: 66MHz
        *-display
             description: VGA compatible controller
             product: Wrestler [Radeon HD 6310]
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
             configuration: driver=radeon latency=0
             resources: irq:41 memory:b0000000-bfffffff ioport:f000(size=256) memory:feb00000-feb3ffff
        *-multimedia:0
             description: Audio device
             product: Wrestler HDMI Audio [Radeon HD 6250/6310]
             physical id: 1.1
             bus info: pci@0000:00:01.1
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: pm pciexpress msi bus_master cap_list
             configuration: driver=snd_hda_intel latency=0
             resources: irq:42 memory:feb44000-feb47fff
        *-pci:0
             description: PCI bridge
             product: Family 14h Processor Root Port
             physical id: 4
             bus info: pci@0000:00:04.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:16 ioport:1000(size=4096) memory:d0100000-d02fffff ioport:d0300000(size=2097152)
        *-storage
             description: SATA controller
             product: SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
             physical id: 11
             bus info: pci@0000:00:11.0
             logical name: scsi0
             logical name: scsi1
             version: 40
             width: 32 bits
             clock: 66MHz
             capabilities: storage ahci_1.0 bus_master cap_list emulated
             configuration: driver=ahci latency=64
             resources: irq:19 ioport:f190(size=8) ioport:f180(size=4) ioport:f170(size=8) ioport:f160(size=4) ioport:f150(size=16) memory:feb4f000-feb4f3ff
           *-disk
                description: ATA Disk
                product: WDC WD15EARX-00P
                vendor: Western Digital
                physical id: 0
                bus info: scsi@0:0.0.0
                logical name: /dev/sda
                version: 51.0
                serial: WD-WMAZA6532013
                capabilities: partitioned partitioned:dos
                configuration: ansiversion=5 signature=5182c187
              *-volume:0
                   description: Windows NTFS volume
                   physical id: 1
                   bus info: scsi@0:0.0.0,1
                   logical name: /dev/sda1
                   version: 3.1
                   serial: b850-6fe3
                   capacity: 21GiB
                   capabilities: primary ntfs initialized
                   configuration: clustersize=4096 created=2012-02-25 10:43:21 filesystem=ntfs label=PQSERVICE state=clean
              *-volume:1
                   physical id: 2
                   bus info: scsi@0:0.0.0,2
                   logical name: /dev/sda2
                   version: 3.1
                   serial: 9c52-1056
                   capacity: 100MiB
                   capabilities: primary bootable ntfs initialized
                   configuration: clustersize=4096 created=2012-02-25 10:43:32 filesystem=ntfs label=SYSTEM RESERVED state=clean
              *-volume:2
                   physical id: 3
                   bus info: scsi@0:0.0.0,3
                   logical name: /dev/sda3
                   version: 3.1
                   serial: c0e64031-96b1-794f-8193-3ce9f125b934
                   capacity: 687GiB
                   configuration: clustersize=4096 created=2012-02-25 10:43:35 filesystem=ntfs label=Acer state=clean
              *-volume:3
                   physical id: 4
                   bus info: scsi@0:0.0.0,4
                   logical name: /dev/sda4
                   version: 3.1
                   serial: b2c5e645-baf4-3a4e-ad21-3c5f8da10059
                   capacity: 688GiB
                   configuration: clustersize=4096 created=2012-02-25 10:43:48 filesystem=ntfs label=DATA state=clean
           *-cdrom
                description: DVD-RAM writer
                product: DVD A  DH16ABSH
                vendor: ATAPI
                physical id: 1
                bus info: scsi@1:0.0.0
                logical name: /dev/cdrom
                logical name: /dev/cdrw
                logical name: /dev/dvd
                logical name: /dev/dvdrw
                logical name: /dev/sr0
                logical name: /cdrom
                version: YA12
                capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
                configuration: ansiversion=5 mount.fstype=iso9660 mount.options=ro,noatime state=mounted status=ready
              *-medium
                   physical id: 0
                   configuration: mount.fstype=iso9660 mount.options=ro,noatime signature=213cf8fc state=mounted
                 *-volume UNCLAIMED
                      description: Hidden HPFS/NTFS partition
                      physical id: 1
                      capacity: 695MiB
                      capabilities: primary bootable hidden
        *-usb:0
             description: USB controller
             product: SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
             physical id: 12
             bus info: pci@0000:00:12.0
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: ohci bus_master
             configuration: driver=ohci_hcd latency=64
             resources: irq:18 memory:feb4e000-feb4efff
        *-usb:1
             product: SB7x0/SB8x0/SB9x0 USB EHCI Controller
             physical id: 12.2
             bus info: pci@0000:00:12.2
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci_hcd latency=64
             resources: irq:17 memory:feb4d000-feb4d0ff
        *-usb:2
             physical id: 13
             bus info: pci@0000:00:13.0
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:18 memory:feb4c000-feb4cfff
        *-usb:3
             physical id: 13.2
             bus info: pci@0000:00:13.2
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:17 memory:feb4b000-feb4b0ff
        *-serial
             description: SMBus
             product: SBx00 SMBus Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 42
             width: 32 bits
             clock: 66MHz
             configuration: driver=piix4_smbus latency=0
             resources: irq:0
        *-ide
             description: IDE interface
             product: SB7x0/SB8x0/SB9x0 IDE Controller
             physical id: 14.1
             bus info: pci@0000:00:14.1
             version: 40
             width: 32 bits
             clock: 66MHz
             capabilities: ide bus_master
             configuration: driver=pata_atiixp latency=64
             resources: irq:17 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:f100(size=16)
        *-multimedia:1
             product: SBx00 Azalia (Intel HDA)
             physical id: 14.2
             bus info: pci@0000:00:14.2
             version: 40
             width: 64 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             configuration: driver=snd_hda_intel latency=64
             resources: irq:16 memory:feb40000-feb43fff
        *-isa
             description: ISA bridge
             product: SB7x0/SB8x0/SB9x0 LPC host controller
             physical id: 14.3
             bus info: pci@0000:00:14.3
             version: 40
             width: 32 bits
             clock: 66MHz
             capabilities: isa bus_master
             configuration: latency=0
        *-pci:1
             product: SBx00 PCI to PCI Bridge
             physical id: 14.4
             bus info: pci@0000:00:14.4
             version: 40
             width: 32 bits
             clock: 66MHz
             capabilities: pci subtractive_decode bus_master vga_palette
        *-usb:4
             product: SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
             physical id: 14.5
             bus info: pci@0000:00:14.5
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:18 memory:feb4a000-feb4afff
        *-pci:2
             product: SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0)
             physical id: 15
             bus info: pci@0000:00:15.0
             version: 00
             width: 32 bits
             clock: 33MHz
             resources: irq:16 ioport:e000(size=4096) memory:fe100000-feafffff ioport:c0000000(size=268435456)
        *-pci:3
             product: SB900 PCI to PCI bridge (PCIE port 2)
             physical id: 15.2
             bus info: pci@0000:00:15.2
             version: 00
             width: 32 bits
             clock: 33MHz
             resources: irq:16 ioport:d000(size=4096) ioport:d0000000(size=1048576)
           *-network
                description: Ethernet interface
                product: RTL8111/8168B PCI Express Gigabit Ethernet controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:06:00.0
                logical name: eth0
                version: 06
                serial: c8:9c:dc:a7:53:dc
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.1.89 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
                resources: irq:40 ioport:d000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
        *-usb:5
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:18 memory:feb49000-feb49fff
        *-usb:6
             physical id: 16.2
             bus info: pci@0000:00:16.2
             version: 00
             width: 32 bits
             clock: 66MHz
             resources: irq:17 memory:feb48000-feb480ff
     *-pci:1
          product: Family 12h/14h Processor Function 0
          physical id: 101
          bus info: pci@0000:00:18.0
          version: 43
          width: 32 bits
          clock: 33MHz
     *-pci:2
          product: Family 12h/14h Processor Function 1
          physical id: 102
          bus info: pci@0000:00:18.1
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:3
          product: Family 12h/14h Processor Function 2
          physical id: 103
          bus info: pci@0000:00:18.2
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:4
          product: Family 12h/14h Processor Function 3
          physical id: 104
          bus info: pci@0000:00:18.3
          version: 00
          width: 32 bits
          clock: 33MHz
          configuration: driver=k10temp
          resources: irq:0
     *-pci:5
          product: Family 12h/14h Processor Function 4
          physical id: 105
          bus info: pci@0000:00:18.4
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:6
          product: Family 12h/14h Processor Function 6
          physical id: 106
          bus info: pci@0000:00:18.5
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:7
          product: Family 12h/14h Processor Function 5
          physical id: 107
          bus info: pci@0000:00:18.6
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:8
          product: Family 12h/14h Processor Function 7
          physical id: 108
          bus info: pci@0000:00:18.7
          version: 00
          width: 32 bits
          clock: 33MHz
xubuntu@xubuntu:~$
pedros
Postby wyliecoyoteuk » Mon Jun 04, 2012 1:29 pm
Looks like a PC world special, (not found on Acer site).
So a guess really.
As it is only a 32bit bus, I would guess no.
Postby pedros » Tue Jun 05, 2012 10:17 am
oh well, back to the shop for me...
thanks folks
pedros
Postby dandnsmith » Wed Jun 06, 2012 1:44 pm
Not sure where that comment about 32-bit bus comes from - I've several examples of (old) systems which can drive 2 monitors from amd radeon chipsets.
Unfortunately, the easiest way I know to check whether 2 monitors are possible is by running WinXP with all the proprietary drivers installed.
Derek
dandnsmith
Postby wyliecoyoteuk » Wed Jun 06, 2012 3:04 pm
dandnsmith wrote:Not sure where that comment about 32-bit bus comes from - I've several examples of (old) systems which can drive 2 monitors from amd radeon chipsets.
Read the display section in the lshw listing. my own Radeon motherboard (which will drive 2 monitors) has a 64bit bus.:)
So does the full version of the 6310, according to Wikipedia.
Seriously though, I could be wrong. I did say it was a guess, but being a budget proprietary motherboard, I wouldn't buy an extra monitor on the off chance.
You can get low-profile graphics cards though, so maybe try it and buy a gfx card if it doesn't work.
Postby dandnsmith » Thu Jun 07, 2012 7:39 am
I see what you're saying, but you've misunderstood what I said - I have several sets of hardware with radeon chipsets which can drive 2 monitors, and they have 32-bit bus.
Derek
dandnsmith
Postby ferrari » Thu Jun 07, 2012 10:58 am
I agree. The architecture shouldn't come into it. I've also had 32-bit machines with radeon (and other graphics) hardware that supported dual display devices just fine.[/code]
ferrari
Postby wyliecoyoteuk » Thu Jun 07, 2012 1:28 pm
I should have been clearer, sorry. I was just pointing out that it is a cut-down cheaper version of the card, the full 6310 has a 64/128bit bus and will drive up to 3 displays.
Knowing how manufacturers trim specs to save even a fraction of a cent per unit, I doubt that a cut-price version will drive 2 displays simultaneously.
I have had to install graphics cards in several manufactured PCs for just that reason. Even ones with 2 outputs will only drive one at a time.
Of course, as I said, I could be wrong.
The documentation as usual, is non-existent, so the only way to find out for sure is to plug 2 monitors in and try it.
As ever,YMMV :)
