TheWizardofOdds LXF regular
Posted: Tue May 01, 2012 4:49 pm Post subject: Windows XP low memory |
I have quite recently installed Windows XP alongside Ubuntu 11.10 on my Desktop so that I can use iTunes.
When I boot up XP it tells me that I am low on memory on j Drive. I think I have only 10 GB in total for XP the PC has a 320GB Hard Drive approx.so it's not like I don't have the space somewhere.
I have very few programs on XP just the bare minimum, so I can't really delete too much to make space without affecting the performance.
What I'd like to do is install Ubuntu 12.04 as it's LTS and stick with it instead of continually upgrading every six months. Normally I upgrade from the Update Manager to the next version. Is this what is creating a space issue? Should I do a fresh install of 12.04 from a disk and partition with XP to create space for both?
I know this is a bit vague, I'm winging it when it comes to computers and learning all the time but this is a bit beyond me (believe me, I done well just installing XP). I just want to be able to run both with no problems.
Any thoughts or suggestions welcome. |
heiowge LXF regular
Joined: Wed Feb 27, 2008 8:21 pm Posts: 1794 Location: Cheshire, UK
Posted: Tue May 01, 2012 5:20 pm Post subject: |
XP install isn't that big. 10GB is loads. I used to cram it on a 2GB SSD with Office 2003 and it still only took up 1.4GB. I also used something called nlite to slim XP down to a bare 250ish MB installed size by removing some of the cruft they jam with it.
On another note, have you considered just installing XP as a virtual PC? Saves messing with dual boot. XP doesn't need much in the way of RAM, and if you've got it spare, it can be a good way of keeping things easy. Also if you get virused (with XP not being secure enough these days), you can just roll it back to a pre-virused state without having to reinstall everything. Plus sorting out GRUB after the reinstall can be a royal pain on a dual boot. _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great. |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3358 Location: Birmingham, UK
Posted: Tue May 01, 2012 6:21 pm Post subject: |
What is your J: drive?
Might it be a flash drive, a network share or an orphan partition?
Windows is normally installed on C: _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
Posted: Wed May 02, 2012 2:16 pm Post subject: |
| heiowge wrote: | | ...On another note, have you considered just installing XP as a virtual PC?... |
I cant find the installation disk so I'm stuck with what I have.
From what I can see iTunes takes up about 2GB, I can't figure out what takes up the rest because when I go into add/remove programs each program seems only to go up to 150 MB max there doesn't seem any obvious way to do a cull and make some room? |
Posted: Wed May 02, 2012 2:22 pm Post subject: |
| wyliecoyoteuk wrote: | What is your J: drive?
Windows is normally installed on C: |
My XP is on J: drive. Not really sure why but it is.
When I check disk usage in Linux I have apparently something like 300GB free!
When I check the disk usage on Linux does it take the J: drive into consideration? Would it recognize it?
When I booted up yesterday I selected 'other Linux versions' and I seem to still have each version of Linux there, can these be deleted? Would it make any difference? |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1547 Location: Guisborough
Posted: Wed May 02, 2012 6:30 pm Post subject: |
In XP goto my computer, what does it say is the free space. May need to change view to details. _________________
johnhudson LXF regular
Posted: Wed May 02, 2012 8:40 pm Post subject: |
Though the initial XP install is small, its undisciplined handling of updates means that it now takes up nearly 10 Gb of the 17Gb drive on which I have it and I have recently begun to get low memory messages because Windows uses the hard dive for swap.
My guess is that, if you have updated XP, it will have eaten more space and, together with your apps, there is now too little room for it to be comfortable using the remaining hard drive space for swap. |
reklan
Joined: Thu Mar 13, 2008 10:41 am Posts: 83 Location: Doncaster, Yorkshire
Posted: Thu May 03, 2012 10:28 am Post subject: |
go to www.piriform.com and get ccleaner.
This will help you delete all teh crap and temp files left behind (including all the installers for the updates that get left behind).
You will be suprise by the amount of crap it will clean for you.. It can also check the registry and cleam that as well.
been using it for years, and never had a problem. One of the best windows programs out there _________________ Don't Dream it....Be it.. |
Posted: Thu May 03, 2012 11:18 pm Post subject: |
The free space thing is complicated.
There is "free space" on a drive, or "free space" on a partition.
Free space on a drive is unformatted, unused space outside of any partition.
Windows drives, for example your J:drive, are partitions, and free space within them is limited to the maximum size of that partition, minus the files stored on there.
Linux installs will be on separate partitions, so free space will be available space on that partition. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
Posted: Fri May 04, 2012 10:28 pm Post subject: |
| Ram wrote: | | In XP goto my computer, what does it say is the free space. May need to change view to details. |
Free space was 322 MB, after downloading and running CCleaner it's now 800MB.
[/quote] |
Posted: Fri May 04, 2012 10:32 pm Post subject: |
| wyliecoyoteuk wrote: | The free space thing is complicated.
Linux installs will be on separate partitions, so free space will be available space on that partition. |
Can I increase the size of the partition?
What determines the size of the partition? I stumbled my way around installing XP, I don't remember having an option on the size of the partition. |
Posted: Fri May 04, 2012 10:36 pm Post subject: |
Can anyone recommend a site or book perhaps that can help me get to grips with this dual booting thing?
I feel like just going back to basics and installing 12.04 fresh and formatting all the other versions of Linux that are floating around in my PC. I don't want to lose Windows however. If only for iTunes. |
Posted: Sat May 05, 2012 12:09 am Post subject: |
1 - always install Windows first - it likes to think it is the only OS in the worrld.
2 - select you favourite Linux distro and ask it to install; before it does so, it should tell you exactly what it plans to do.
3 - if it is not clear from what it puts up that it is going to retain Windows, abort and seek further advice. (Don't blindly say Yes.)
Nearly all distros use GRUB to handle the dual boot but there are two versions and they are not compatible. This does not matter if you have Windows and one Linux distro but it does if you have more than one Linux distro.
With XP you will have no problems; with Vista and Windows 7, you may encounter problems when Windows updates itself because it tends to overwrite the instructions to load GRUB. This usually means inserting a CD and restoring the code that loads GRUB. |
Posted: Sat May 05, 2012 10:15 am Post subject: |
You can change the size of a partition using Parted, the disk utility in Ubuntu.
Thing is, if there are partitions either side of it, you would have to move or delete them before you can resize it.
Be careful, as it is always possible to mess things up. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
