Right Click, search wont work in Thunderbird
Postby Narendra » Sat Apr 21, 2012 6:46 pm
Hello,
Please advise.
Right click search the web feature won't work for ubuntu thunderbird.
Thank you.
Narendra
Narendra
Postby Rhakios » Sat Apr 21, 2012 8:24 pm
You're right, it doesn't work. However, see this thread for a fix. Essentially, install the OpenSearch add-on, test search, then you can remove it and search will still work.
I've just tried this and can confirm the fix.
Postby Narendra » Sat Apr 21, 2012 8:44 pm
I have done it and it works.
Narendra
Narendra
