mailman
mailman
Postby neilj » Fri Apr 20, 2012 1:11 pm
I am trying to install mailman. I get the following error
Access denied per /etc/httpd/conf/webapps.d/mailman.conf
I have changed the permissions to read/write for everyone. I have changed Deny to Allow. But same error.
Any help will be appreciated.
neilj
Postby Dutch_Master » Fri Apr 20, 2012 1:19 pm
You need to restart services (like mailman) in order to pick up any changes you've made. :)
mailman
Postby neilj » Fri Apr 20, 2012 1:40 pm
Thanks, That has worked
neilj
mailman error logs
Postby neilj » Fri Apr 20, 2012 1:47 pm
I have a new problem when trying to create a list. It says the error can be found in the mailman error logs. Where do I find them.
Is there any other mailing list manager. I have something called mailking on windows running on a virtual machine. Is there something like that available for Linux?
neilj
Postby Dutch_Master » Fri Apr 20, 2012 1:58 pm
Error logs can be found in /var/log so that should be your first stop. No idea on the mailing list manager, don't use them... :P
