/dev/disk/by-id cleanup
indijanc
PostPosted: Wed Apr 04, 2012 4:03 pm    Post subject: /dev/disk/by-id cleanup Reply with quote
Is there any way to clean up stale devices/symlinks in the /dev/disk/by-id folder?
I have a SLES 11.1 with a SAN connected disk array. I'm using a program for disk replication and presenting the disks to the server. The program also enables the disks and creates a volume group on top. When it finishes it cleans up after itself (remove vg, unpresent etc.). After a few days of running it, the /dev/disk/by-id folder holds a large number of files (mostly softlinks to lvm devices). Is there any way to clean/remove these? So far only reboot helps Smile
PostPosted: Thu Apr 05, 2012 1:54 am    Post subject: Reply with quote
Do you mean that the directory is full of links that point nowhere? If so, this command will remove them.
Code:
find -L /dev/disk/by-id -type l -exec rm "{}" +
The -L options makes find follow symbolic links and use information fro the file linked to rather than the link itself, so the only links it sees as links (-type l) are broken ones (or links that point to an unreadable file, but that won't happen if you run this as root).
indijanc
PostPosted: Thu Apr 05, 2012 8:42 am    Post subject: Reply with quote
Thank you nelz, that does clean up the stale links.
I'd rather use a udev cleanup command or something similar though, since udev creates these links and takes care of them if I'm not mistaken. Is there any udev (or something similar) cleanup mode/command to take care of this? So far I haven't found any clues on "proper" removal of these stale softlinks.
Thanks for the help Smile
ferrari
PostPosted: Tue Apr 10, 2012 4:41 am    Post subject: Reply with quote
I'm surprised you had stale links, because AFAIU, udev creates/deletes these dynamically (via kernel uevents) as any disks are detected or removed, but maybe your disk replication app is responsible for this behaviour?
