Requires installation of untrusted packages [SOLVED]
Postby towy71 » Thu Mar 29, 2012 9:22 pm
I have an installatiuon of LXF Ubuntu remix with gnome three and the latest update gives the above message, does anyone know what it means?
libgudev-1.0-0 libudev0 linux-generic linux-headers-3.0.0-17 linux-headers-3.0.0-17-generic linux-headers-generic linux-image-3.0.0-17-generic linux-image-generic linux-libc-dev udev
is the file in question
Postby Dutch_Master » Fri Mar 30, 2012 1:29 am
Simply that apt wasn't able to verify the PGP signatures of these packages. You can import the signature by hand (if you have it) or use aptitude or Synaptic to hunt it down, provided you have the right repo's enabled. Start with 'keyring' as your search string ;)
Postby towy71 » Fri Mar 30, 2012 7:53 pm
All is good now, it must have been a blip of some sort :roll:
