LXF154 Answers LXFUSB please cp causes errors
Postby rbooth » Wed Feb 22, 2012 5:48 am
In LXF 154, Feb 2012, in the Answers section, Page 199, in answer to the question titled LXFUSB please, one response was to issue the command "cp /dev/dvd filename". I have tried this command on four of your coverdisks (155, 154, and both 153) and get the following:
rbooth@houston:~/Temp$ cp /dev/dvd LinuxFormatCoverDisk.iso
cp: reading `/dev/dvd': Input/output error
rbooth@houston:~/Temp$ sudo cp /dev/dvd LinuxFormatCoverDisk.iso
[sudo] password for rbooth:
Note that I tried both as normal and super user.
I am using Ubuntu 10.10, since newer versions are, um, undesirable.
rbooth
Postby nelz » Wed Feb 22, 2012 9:19 am
Does /dev/dvd exist? Most distros are set up to create a symlink from the real device, usually /dev/sr0, to /dev/dvd. Look at the output from mount or df to see the actual device and use that instead of /dev/dvd.
Postby nelz » Wed Feb 22, 2012 11:06 am
BTW don't use this on DVDs 154 or 155 (or 156), use the dvd2usb script from the DVD instead.
Postby rbooth » Fri Feb 24, 2012 4:47 am
/dev/dvd does exist. The copy command created a file 4.1GB in size. Then it issued the error message.
rbooth
Postby nelz » Fri Feb 24, 2012 9:04 am
Ah, you didn't mention that before. Did you try to use the image file it created?
Also, from DVD154 onwards, this is no longer necessary.
Users browsing this forum: Google [Bot], Yahoo [Bot] and 3 guests
