Weatherlawyer
Joined: Fri Nov 27, 2009 2:24 pm Posts: 53 Location: Stoke on Trent, England.
Posted: Tue Jan 31, 2012 1:02 am Post subject: Sound drivers and hardware scans. Solved. |
What application do I need to see what motherboard I am using?
I did a test of my computer before upgrading that showed me what was and what wasn't OK.
I have no idea where it is now with Ubuntu 11.4.
I need a sound driver. Presumably I'll be OK with Avrak until this get sorted. Or is there a more Linux friendly driver out there waiting in the dark? _________________ I would very much like to be nice. If this is not your day, I am sorry about that.
Last edited by Weatherlawyer on Tue Jul 31, 2012 10:30 am; edited 1 time in total |
Rhakios Moderator
Joined: Thu Apr 07, 2005 12:18 am Posts: 7484 Location: Midlands, UK
Posted: Tue Jan 31, 2012 8:38 pm Post subject: |
I found the easiest way to find out what motherboard I have is to open the case and have a look (it might also be reported in the BIOS, I don't remember).
If you just want to find out what sound card you have, then just do:
lspci | grep -i audio
For example, this gives me:
| Code: |
rhakios@pythia:~$ lspci | grep -i audio
00:05.0 Audio device: nVidia Corporation MCP61 High Definition Audio (rev a2)
Which is enough information for the basis of a search.
Edit: programs like hwinfo, tend to give a lot more detail, without it necessarily being of much use, for example, it gives a system board identifier for my PC, but doesn't tell me the exact model. _________________ Bye, Rhakios |
MessedUpHare
Joined: Mon Oct 26, 2009 6:33 pm Posts: 10 Location: London
Posted: Wed Feb 01, 2012 8:15 pm Post subject: |
you could use dmidecode to find what the motherboard is saying it is... you havto run it as root, though...
[/code] |
Rhakios Moderator
Posted: Wed Feb 01, 2012 9:59 pm Post subject: |
For me, that only gives to same info as hwinfo, i.e. not the motherboard's full product name. _________________ Bye, Rhakios |
Weatherlawyer
Posted: Thu Feb 02, 2012 3:59 am Post subject: |
That just about sums up what is wrong wioth Linux.
Most Windows users expect to find a programme they just need to click on and the computer does the rest.
I don't have a clue how to use the command line. All the replies for help here require I learn. _________________ I would very much like to be nice. If this is not your day, I am sorry about that. |
towy71 Moderator
Joined: Wed Apr 06, 2005 3:11 pm Posts: 4176 Location: wild West Wales
Posted: Thu Feb 02, 2012 12:29 pm Post subject: |
| Weatherlawyer wrote: | | Most Windows users expect to find a programme they just need to click on and the computer does the rest. | I'm fairly sure there isn't a Windows program that would properly identify the motherboard, and definitely Windows will not have bundled drivers for most hardware  _________________ still looking for that door into summer |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1569 Location: Guisborough
Posted: Thu Feb 02, 2012 12:42 pm Post subject: |
| Weatherlawyer wrote: | That just about sums up what is wrong wioth Linux.
I don't have a clue how to use the command line. All the replies for help here require I learn. |
There's nothing wrong with Linux.
I use the command line a lot in Windows to launch programmes.
That's your bad, your never to old to learn. _________________
nelz Moderator
Posted: Thu Feb 02, 2012 1:34 pm Post subject: |
You don't need to learn anything, or even type anything. Open a terminal then copy and paste the command from the reply. Maybe three mouse clicks, which is quicker than doing it with most GUI programs.
The command line is an advantage to be embraced, not a foreign land full of dragons. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
towy71 Moderator
Posted: Thu Feb 02, 2012 3:21 pm Post subject: |
| nelz wrote: | | The command line is an advantage to be embraced, not a foreign land full of dragons. | True, but it is still powerful enough to bite you on the derrière  _________________ still looking for that door into summer |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3369 Location: Birmingham, UK
Posted: Thu Feb 02, 2012 3:55 pm Post subject: |
Answering questions with a single line command that can be cut and pasted into a terminal is easier than writing half a page of "click this, select that" descriptions.
Actually, you often see that on windows forums as well, as most programs and config tools can be launched from the command line.
In fact there are some tools in windows that only work properly from the CLI.  _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
nelz Moderator
Posted: Thu Feb 02, 2012 5:24 pm Post subject: |
And you can hurt yourself with a GUI? _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Posted: Thu Feb 02, 2012 9:30 pm Post subject: |
Of course you can.
If you do not continue, the application will not be completely installed, and may not function correctly.
Do you not want to continue?
Yes no _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
MessedUpHare
Posted: Thu Feb 02, 2012 9:43 pm Post subject: |
Personally, I find hardware issues in windows harder to deal with - especially if the owner has inadvertently installed the wrong driver, the machine can report incorrectly...
Anyhoo, Windows/Linux arguments are fairly dull..
I'm kind of out of ideas with regards to polling the mainboard... Beyond the previously mentioned checking the physical board...
Sorry to dissapoint |
nelz Moderator
Posted: Thu Feb 02, 2012 9:45 pm Post subject: |
That was meant to be a rhetorical question, which would have been clear had I typed can't instead of can  _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Ram LXF regular
Posted: Thu Feb 02, 2012 10:33 pm Post subject: |
| Rhakios wrote: | | For me, that only gives to same info as hwinfo, i.e. not the motherboard's full product name. |
Pretty darn close for me.
# dmidecode 2.9
SMBIOS 2.5 present.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: ASUSTeK Computer INC.
Product Name: Crosshair III Formula
Version: Rev 1.xx
Serial Number: 102426410000199
Asset Tag: To Be Filled By O.E.M.
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: To Be Filled By O.E.M.
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0 _________________
