Another Python Freebie... An Audio Sweep Generator.
Postby Bazza » Sat Dec 17, 2011 11:42 am
Hi all...
DM might be interested in this little devil...
A Linux Python 3.x.x code to sweep the audio spectrum from 4KHz down
to 100Hz and back again. (It is effectively a siren sound.)
Written so that anyone can understand how it works...
I will be releasing a Python 2.x.x version to code.activestate.com soon.
Watch out for wordwrapping etc...
Enjoy finding simple solutions to often VERY difficult problems... ;o)
# SweepGen3x.py
# A DEMO Audio Sweep Generator from 4KHz down to 100Hz and back up again
# using standard Text Mode Python. Another kids level piece of code for a very
# simple, FREE, Test Gear project... Hey, it is not perfect but a simple audio
# sweep generator for FREE, what more could you want!
# This working idea is copyright, (C)2010, B.Walker, G0LCU.
# Initially issued to LXF under the MIT licence.
# Written in such a way that anyone can understand how it works.
# Tested on PCLinuxOS 2009 and Debian 6.0.0 using Python 3.1.3 and 3.2.2.
# "/dev/dsp" IS required for this to work; therefore if you haven't got it then
# install "oss-compat" from you distro's repository. Ensure the sound system is
# not already in use.
# It is easily possible to lengthen the higher frequency playing times and VERY
# easily alter the output level and to speed up or slow down the sweep speed.
# I'll let the big guns do that for you...
# IMPORTANT NOTE:- Every EVEN number of bytes is a symmetrical "square" wave BUT
# every ODD number of bytes has preference for the "space" by one byte.
# To run this DEMO type at the Python prompt......
# >>> exec(open("/full/path/to/SweepGen3x.py").read())<RETURN/ENTER>
# ......and away you go.
# Note:- NO import[s] required at all, good eh! ;o)
def main():
   # Set all "variables" as globals, my choice... ;o)
   global mark
   global space
   global freq
   global stringlength
   global n
   global sweep
   # Allocate initial values.
   mark=b"\xff"
   space=b"\x00"
   freq=mark+space
   # 8KHz is the default sample speed of the sound system.
   # Therefore this sets the lowest frequency, 8KHz/80=100Hz...
   stringlength=80
   n=0
   sweep=0
   # A simple screen clear and user screen for a default Python window...
   for n in range(0,40,1):
      print("\r\n")
   print("Sweep Generator DEMO from 4KHz down to 100HZ and back again...\n")
   print("This just gives 5 SIREN like sweeps but it is enough for this DEMO...\n")
   print("Copyright, (C)2010, B.Walker, G0LCU.\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n")
   # Open the audio device, "/dev/dsp" for writing.
   audio=open("/dev/dsp", "wb")
   # Sweep for five times only for this DEMO...
   while 1:
      freq=mark+space
      stringlength=80
      n=0
      while sweep<=4:
         # Sweep down from 4KHz to 100Hz.
         audio.write(freq)
         # Add a trailing 0x00 byte.
         freq=freq+space
         # Quit when length of "freq" byte-string is 80 bytes.
         if len(freq)>=stringlength: break
         audio.write(freq)
         # Add a leading 0xff byte.
         freq=mark+freq
      while 1:
         # Sweep back up again from 100Hz to 4KHz.
         # Start with an empty byte-string.
         freq=b""
         # Now create a new byte square wave byte-string.
         for n in range(0,int((stringlength)/2),1):
            freq=freq+mark
            freq=freq+space
         audio.write(freq)
         # Create a new byte-string reduced by one byte.
         # This removes one 0xff byte.
         stringlength=stringlength-1
         # Quit when length of "freq" byte-string is 2 bytes.
         if len(freq)<=2: break
         freq=b""
         # Now create a new byte-string reduced by one byte.
            freq=freq+mark
         for n in range(0,int(((stringlength)/2)+1),1):
            freq=freq+space
         audio.write(freq)
         # This removes one 0x00 byte.
      sweep=sweep+1
      # Ensure a complete exit from the loop.
      if sweep>=5: break
   # On exit ensure the audio device is closed.
   audio.close()
main()
# End of SweepGen3x.py DEMO...
# Enjoy finding simple solutions to often VERY difficult problems... ;o)
Enjoy banging the metal and getting something useful for your home
electronics workbench...
73...
Team AMIGA...
Bazza
