NAS suggestions
Postby Brian Hunter » Fri May 27, 2011 9:13 pm
bobthebob1234 wrote:Reasons:
  • Cheap
  • Works with penguins
  • Allowed me to put what ever drives I wanted in
  • Supported raid 1
  • USB ports for printer (and it works to :D)
  • Low power (sleep mode, etc)
  • Gigibit ethernet for when I get gigabit switch to fling massive files around my network
  • Added bonus of dvd drive :D
CIFS/SMB communication will work with linux and winblows (assuming you have samba client installed on linux). I actually have a share on my nas mounted on my myth tv box via samba.
I could have gone for a plug server thing a me bob and installed everything myself, but I just wanted something I could turn on, it work without any fuss and just be there
Nice one, cheers. I basically want the same, something that just works.
Good point on the drives, need to make sure i'm not being tied down to a particular vendor.
Thanks again.
Brian Hunter
Postby drws » Tue May 31, 2011 6:39 pm
I'd second the lg nas recommendation. (if you can find one)
got mine 8-9 months ago and its been on 24/7 since then with only the odd reboot for firmware updates.
drws
Postby mande01 » Tue Nov 15, 2011 3:55 pm
I got me a Netgear Stora.
i think they have a bad name but I got into it via ssh from using this site www.openstora.com/.
I now control it via webmin, very sweet!
two 1.5 Tb drives, teh device is more or less teh exact same size as the two drives!
With a little tweaking you can do anything.
The default set up is good, but they direct you to mystora.com to access your NAS, very weird and big brother ish.
But i just turned off the redirect as per the wiki at openstora.com.
Oh and I got the empty box off ebay for €60!
All works fine with no complaints, currently rsyncing 65GB of photos; ext drive to NAS to web hosting.
Very happy!
Derry
mande01
Postby mande01 » Wed Nov 23, 2011 11:01 am
mande01
