Full backup hard drive
Postby bobthebob1234 » Sat Jul 16, 2011 2:52 pm
jim@vle1:~$ df -h
Filesystem            Size  Used Avail Use% Mounted on
/dev/sdb1             294G  294G     0 100% /backup-hdd
What happens now?
Backups are still appearing, and ls -lh says they are about the right size (5.5gb tars, once a week), however extracting the latest one I get
gzip: stdin: unexpected end of file
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
Are they really there, overwriting old ones or what?
I have used webmin to set up a filesystem backup (well a directory backup).
I guess I need to write a quick script to delete old backups?
Re: Full backup hard drive
Postby nelz » Sat Jul 16, 2011 4:07 pm
bobthebob1234 wrote:Are they really there, overwriting old ones or what?
I would hope not, it would be a lousy backup program that overwrote the previous backups before verifying the new ones.
I'd suggest deleting some of the 50-odd old backups you have to make some space, or switch to a system that uses incremental backups.
Postby guy » Sun Jul 17, 2011 5:01 pm
What is your backup program supposed to do when the drive fills up?
That's a bit rhetorical - I never like challenging the program's quality with real-life boundary conditions like that. Yes, get rid of the oldest backups to create some space - just check whether you should be archiving them somewhere first!
A routine script to archive/delete the oldest file after backing up might be useful - assuming of course that it behaves sensibly if the archive medium is full!
Return to Discussion
