Adroid pod catcher
Adroid pod catcher
Postby tedius » Wed May 25, 2011 3:47 pm
I've just got a HTC Wildfire and am looking for a good pod cacher for it, can anyone suggest anything?
tedius
Re: Adroid pod catcher
Postby DaveS » Sun Jun 12, 2011 9:06 pm
tedius wrote:I've just got a HTC Wildfire and am looking for a good pod cacher for it, can anyone suggest anything?
Beyondpod worked really well on my Wildfire. All the others I tried had some limitation or other. Good luck.....
Mostly Minty with a dash of Puppy......
DaveS
Postby Ram » Tue Jun 14, 2011 10:51 am
I also use the free version of BeyondPod.
Postby Brian Hunter » Tue Jun 14, 2011 12:43 pm
I didn't like any that I tried, so I use gpodder on my system to download podcasts and just sync them to my phone when I plug it in.
Brian Hunter
Postby Arthur_Dent » Wed Jun 22, 2011 1:48 pm
If you like the idea of a command-line, set-it-and-forget-it, run from cron, podcatcher, you can't beat Podracer...
Arthur_Dent
Listen
Postby jonrob » Wed Aug 03, 2011 9:54 am
I use Listen, by Google.
It's very simple, so maybe not the best choice if you want lots of features.To manage your subscriptions, it uses a 'Listen Subscriptions' folder in Google Reader - this is probably its best feature since it makes your podcasts available on any web connected computer, and it also means you don't have to search for subscriptions on your Android phone's tiny screen!
jonrob
Return to Discussion
Users browsing this forum: Bing [Bot] and 3 guests
